I have been having this vibration problem for quite some time now. I will be driving normal, when I go into the next gear (doesnt matter which) I will get a really bad vibration that lasts through out the RPM. But it doesnt always happen, mostly under hard shifting. It does happen under normal driving though, maybe 1 in 8 shifts gets the vibration. It could be there in 2nd gear, and gone in 3rd... Or the other way around. It is in no set gear which leads me to believe its not in the trans. I never get a vibration when the car is not in gear, or when the clutch is pushed in. Also if I shift to 3rd for instance and get the vibration, I can push the clutch in for a second and let it out slowly in the same gear, the vibration will go away.
What could my problem be? I think it could be the clutch. I believe it is stock, but the car is a 4cyl conversion. So I have no Idea. I know the pressure plate is ford blue. Any suggestions would be great. Thanks
Tony
Discussion Starter · #2 ·
