Will valve springs off E7's work on gt40's or gt40p's. If not which ones will and where can I get them and for how much?
They will fit, but why would you want to put stock E7 springs on GT40 heads? With a new head I would recommend new springs. If you already have springs that are matched to a particular camshaft you can just put them on and make sure your installed height is correct and you will be just fine.
I'm not going to be using my stock E7 springs. I have a set of Crane springs that were for E7's and I was wanting to know if they use the same springs(gt40's/E7's).
