1 - 1 of 1 Posts
well im not sure if i have valve float or not, but since the motor is coming out to shim some lash adjuster i might as well do valve springs at the same time.
IM NOT USING MODMAX SPRINGS
new ford stockers @ 2.30 each=~80 bux
shm-do i need to machine heads?
12.50 each =400 for the set
comp=do they have 4v springs? are they rebadged modmax, wtf is up with this. lead time?
what other options do i have here.
add 100 for new lash adjusters.
id really like to keep this low budget but if i need to spend the money to make it better, then i will.
any help in this subject would be appreciated
1 - 1 of 1 Posts
