i want to get valve covers where i dont have to cut the oil baffles
and that will take my 1.72 rollarrockers
i was thinking trickflow
any suggestions i really dont want to run stock covers
You have two choices:
1. Get the extra tall valve covers from FRPP or others and add a 1" phenolic spacer to your intake so your throttle linkage will clear, which usually forces you to get an aftermarket cowl hood; or,
2. Deal with the oil baffle issue. On the bright side, the polished aluminum FRPP valve covers, albeit pricy, clear the rockers by simply cutting the vertical flange off the baffle and rotating it 180 degrees.:D
