valve cover breather fittings or adapters???
My IAC valve is preventing me from running a push in breather in my valve cover. Does anyone know of a fitting that will push in the grommet and let you mount the breather at an angle? I would actually prefer some sort of AN fitting that will press in and allow me to run a hose from the valve cover to a catch can. The only option for using an AN fitting I have seen requires you to weld a bung on the valve cover, and I'd rather not do that.
Below are a couple of pics that show the problem....
Thanks in advance
Check out Trickflow or Comp polymers
