I am considering getting on and using the remote thingie near my gauges. But, where are you mounting the unit? I'm pretty sure it's illegal here and I don't want the 5 o's seeing it.
I mounted mine right above the Rear View Mirror. If you get the suction cups up high enough, the detector is almost impossible to see from the outside of the car. I then just used an extended phone cord and ran the wiring over to my drivers side a pillar and down under my dash. If you don't know where to look, you won't see it. It still picks up radar at great distanes. , I didn't use the visor mount, just the standard one.
Let me know if you need a picture, I can run out and snap one.
Hope this helps,
Michael
also, I wouldn't waste my money with the concealed display... mounting it this way should fix your problem
I guess you'll have to find another way when your top is down - sorry didn't see your car was a vert.
I also mount mine high, above the rear mirror (I lowered my mirror to give me enough room). It works best up high, vert or coupe.
A. It's not illegal in CA to have a radar DETECTOR. It's illegal to have a radar JAMMER in CA which is not what the valentine is.
B. I have mine above my rear view mirror. I then ran the wire where the window meets the top of the roof, down the pillar and hot wired it to the radio
Discussion Starter · #6 ·
Thanks guys.
