maybe someone can help me here. Installing my new motor, I broke a vacume line coming from a bundle of vacume lines which are attached to a tree right behind the passengers strut tower on the bottom. Out of this bundle of lines, I olny have one that is hooked to one of the small lines out of the back of the intake. The rest of them where used with smog, which I do not have anymore. Anyways, trying to move this bundle around, from the engine heat these things are very very brittle, I broke 3 lines right behinf the bundle. I was thinking since I onoy am using one of these lines, coukd I remove this "tree" and "bundle" and run a vacume line from the tree on the firewall to the back of the intake. Or should I buy all new lines and tree and use what I need? Thanks!
-Slash
re
You can reconnect them using rubber vaccum hose to slip over the ends w a dab of RTV to seal them together
