1 - 20 of 20 Posts
Ive had the car done for a couple weeks now and slowly getting all the bugs worked out of it. Trying to get the Cobra wiring to work with the V6 wiring is a PITA but worth the time in the end. The complete swap took me about 6 months from start to finish with it being worked on only on the weekends. I dont have and #s on it yet but Ill try to get some soon enough.
As far as whats done to the motor, its a 98 motor with no EGR or IMRCs, BBK long tubes and h-pipe with a MAC catback. In the rear I swaped to an 8.8 with 3.08 gears already in it. I may swap to 4.10s with the nitrous or go with 4.30s and stay NA. Suspension wise, Ive got Tokico 5-ways all around, X2C Coilovers up front and Eibach Pro springs in the back, MM caster camber plates, Cobra front brakes, Triax, and AJE k-member and a-arms. Right now Im still getting used to driving something that has twice as much power as the V6 I pulled out. All in all Im just glad to be driving it again!!! :joy:
Cool man! Sounds like a well planned out project that worked out great
congrats! You N E E D to do a gearswap asap!! Those 3.08 gears sound horrible! The stock 3.27 gears in the real Cobras are painfully long, I can only imagine how much your gears are sapping the motors power.
Put in a set of 4.10's or 4.30's and it will feel for you like you've added an instant 60rwhp/rwtq.
Sounds like a really nifty project. I'd love to see some pics as well.
Would it have not been easier to just forge the internal and throw on 15lbs of boost......just curious it was what I had wanted to do to my v6.
Getting a transmission to survive behind the blown 3.8s seems to be the problem. The T-5 they come with is doo-doo, and a V8 transmission doesn't bolt right in.
Discussion Starter #8 (Edited)
It looks stock for the most part. I could have done a lot of things with the V6, but in the end, its still a V6 and its really not what I wanted anymore. Now Ive got a much better power plant to work with.
The things Ive found out that dont work so far are the front corner lights, reverse lights (from it being an auto before), a/c, radio (needs surpressor), cruise control, and Im sure a couple other things ill find along the way.
Job well done bro. How's it feel from going to a 180hp car to a 305hp one? ;) My car has insurance now. So I'll seeya on the streets. You going to the TR track day? -Mark
Discussion Starter #16
Im going to try and make it. Ive still got to brake the clutch in and figure out hwo to do a burn out. :D Ill have to stop by your place so you can take it for a spin. Thanx again for all your help and patience, I couldnt have done it without your help.
Bro I like your set up you didn't have issues with it
1 - 20 of 20 Posts
