V1 S trim sbf kit 94-94 setup for 8lbs of boost. Kit is mostly new, headunit is good shape ready to bolt on. Sbf $2800 shipping available from va
about the only thing that is moved on this kit,is the alternator, it's moved up towards the water neck and the head unit is pretty close to where the alt used to sit..its a nice kit, ive had a fewAny pics of it mounted? I'm not sure what accessories are affected or moved, etc.
Yes, the vortech kits for fox and 5.0 sn cars require a smog pump or a smog pump eliminator.I wonder if it allows the usage of the stock smog pump bracket? I've relocated my A/C compressor to the smog pump bracket with a custom adjustable mount.
Anyway, free bump!![]()
You wanna buy it? 🙃I wonder if it allows the usage of the stock smog pump bracket? I've relocated my A/C compressor to the smog pump bracket with a custom adjustable mount.
I am actively looking at various superchargers for my rig, but my configuration isn't like every fox or sn95 out there, because it's crammed in an early Ranger with relocated A/C, no smog pump, etc. Hence me asking questions..You wanna buy it? 🙃
I’d guess this would fit better than most with the brackets sitting as close to the motor as possible and short piping. Belt configuration can be ran however seen fitI am actively looking at various superchargers for my rig, but my configuration isn't like every fox or sn95 out there, because it's crammed in an early Ranger with relocated A/C, no smog pump, etc. Hence me asking questions..
