Can I use a stock V6 94-98 Brake booster with my stock 88 5.0 master cylinder and stock brakes?
The reason I ask is because my brake booster needs to be replaced, my dash is currently out for a heater core replacement, a 5 speed swap(swapping in pedal assembly at the moment), and i'm in the process of collecting all the parts for a 5 lug 4 wheel disc conversion, using 94/95 V6/GT brakes.
However I do not have everything I need for the 5 lug swap, so I'd like to at least get the SN95 brake booster in while my dash is out and use it with my stock brakes, until I have everything I need to finish the 5 lug swap. Is this even possible?
very possible. you will have more assist thus a softer pedal.
Hey,
thank you very much for the reply. This makes my life so much easier. I'll be picking up a 94-98 V6 booster this weekend.
