I've got #30 lbs. injectors installed on my motor. What all do I need to have, to be able to use them, with the motor running the way it should?
Are you using stock heads?, Ported?
I think those 30lb injectors are too big for your combo, unless you plan to force feed it.
Swap back in your stock injectors or I can send you a set of factory FOrd injectors, with 2000 miles on em. (21lb, stock is 19lb).
Another option is to get a custom chip burnt.
Ported, a lot. Going Gt-40 soon.
They're still too big.
You will need a mass air meter calibrated for 30/lb injectors.
But as said above unless you have some serious flowing Heads, or a supercharger, Nitrous,etc... those 30/lbrs are overkill
Discussion Starter · #6 ·
Nitrous is also being used..
