1 - 20 of 20 Posts
Looking at getting one of these to replace the none existent one on my 90 GT. Anyone running one of these that can post pics? Any reviews out there? Any clearance issues with lowered mustangs? Mine is lowered 1.5".
Thanks!
My 91 GT I just got has one of these on it, discovered it when I tried to get a jack under it. Is it stock? My 89 LX does not.
At stock ride height w stock tires and wheels the spoiler is about 7 inches from the ground, it sticks down 3.25 inches from the lower crossmember. I suspect your lowered car will have no problems w it
Be forwarned when it does scrape the ground it has a nasty sound thats for sure. I prefer the plastic ones, they are more forgiving when it comes to things like that.
I use a bag ass explorer one so I’m sure you won’t have any issues.
Ford used plastic for a reason. There is a ton of evidence on mine that it's met the ground more than once. The plastic ones bend and give and bounce back. Aluminum will bend and give and just be all bent up.
And then you need a new one or to fix the one you have as best as you can.
Discussion Starter · #13 ·
An aluminum deflector will get all bent up.
Ok, this is good info! I never thought of that. Maybe a plastic one is the way to go... This has been insightful!
popular and effective upgrade back in the day was using the old ford ranger deflector as it was bigger and wider, although i'm guessing finding one of those today is impossible
  • Like
Reactions: 90trunk
The 83-88 Ranger/Bronco II front valence air dam. E3TZ-100001A06-B. I've had mine on the car since 2002.
1065927
  • Like
Reactions: pkstang
Another similar option is the '89-92 Ranger / '91-94 Explorer air dam. Rockauto.com lists it as a "air deflector" for the Ranger and as a "valence" for the Explorer; not sure why the terminology is different, but whatever. Part number is FO1092161 (#E9TZ17626A), under $12.
I've had a junkyard one on mine for years. The air dam is pretty much the full width of the car, and wraps back - I had to cut it a bit on the sides to make it even with the leading edge of the wheel wells.
  • Like
Reactions: pkstang and 90trunk
Great info! I like how it wraps around and the price is much lower than I would have imagined.
i like that it extends more on the sides... looks better than the ranger i have
and for that kind of money not even worth going to the junkyard, although junkyards are fun
‘93 Mustang LX
I bought one one line after a quick search. I had to cut a few inches in length out of the middle, but it works well. I can't believe the markup on the aluminum one from LMR. LOL, wow.
1 - 20 of 20 Posts
