· Registered
It is hard to find part numbers without applications sometimes. Here is a bunch of info I gathered on NAPA fan switches. The on and off temps were not consistant. So some just have what must be an "on" value. There are a variety of connections for these. 1 wire, two wire, three wire. But you can always copy the part number and look on NAPA on line if you find the temps you want.
NAPA Fan switches
Part number On Off Threads
FS100SB 216-232 201 3/8x18
FS102SB 216-232 198-218 M22x1.5
FS103SB 200-210 1/2x14
FS110SB 224-236 212 3/8x18
FS111SB 229-245 3/8x18
FS112SB 213-229 3/8x18
FS120SB 193-207 175 1/2x14
FS121SB nodata
FS130SB 191-198 182-189 M16x1.5
FS133SB 198 M16x1.5
FS147SB 194-203 M16x1.5
FS150SB 191-198 182-189 M22x1.5
FS151SB 2 circuit 190-209 209-226 M22x1.5
FS166SB nodata
FS176SB 194 185 M16x1.5
FS186SB 196-201 M16x1.5
FS205SB 185 M16x1.5
FS207SB nodata 3/8x18
FS211SB nodata
FS244SB 199 M18x1.5
Erich
· Registered
Discussion Starter · #2 ·
Attempt at better table.
NAPA Fan switches
Part number Temp On Temp Off Threads
FS121SB nodata
FS133SB 198 M16x1.5
FS166SB nodata
FS205SB 185 M16x1.5
FS211SB nodata
FS244SB 199 M18x1.5
· Super Moderator
Good stuff, thanks for sharing
· Registered
Discussion Starter · #6 ·
I looked at some of the applications of the chart. It seems alot of hondas used electric fan controls (some of the metric ones).
If you go here http://www.dmauto.com/web/dmauto/search/
you can paste in the part numbers, and go to "other vehicles that fit this part" you can get all the applications. So if you want, you could then go to your local non-napa store and try to get the part in a different brand. However, the napa prices-especially with the first part of the list are pretty low like 12-15 bucks.
Erich
