My passenger-side tweeter (Mach 460 system on a 2001 GT) makes an intermittent squealing/crackiling noise. It started last summer and sorta went away. Now it's starting up again.
I'd like to start off by swapping out another speaker in its place. Does anyone know of a comparable speaker to swap it with? Where would be the best place to get one?
Has anyone else had this problem? What did you do to fix it?
There really isn't much compatable with the stock mach system. I'd try to find a friend with a stang and borrow his. If that doesn't work, lots of audio shops will take stock systems in trade and often have some of them sitting around. They may let you borrow one if you intend to buy it if it works.
You might also be able to find one at a junkyard for a decent price. Then you'd either have an extra, or you could just take it and plug it into a wall outlet for some fun...
