I posted this in 94/95 tech but no help. Hopefully you guys can help thanks, Caleb.
:My brother-inlaws 95 GT was wrecked in the front and it needs a
new front clip. The front clip is $2500 and he found a 95 V6 in good shape for $3500. My questions are what parts are the same
between them. His GT has good parts from the motor back. Everything from pullies forward is gone and the frame is bent pretty bad. Thanks guys for the help.:
G
I did this myself a year or so ago...... 94 v-6 to gt if they are both manual or both autos then it's not as bad as it seems.....need to change engine/trans and rearend, then wiring harness from firewall forward (has two actually left and right) includes fusebox etc. you have to remove inner fender covers to do this. The computer of course. Engine accessories etc. are in different spots but the gt harness takes that into consideration of course. other than that it's an odd or end here or there...not too bad, did mine in a 3 day weekend....after I had all the parts...mine was also adoe-t5 so I had a little more to do.
best of luck
David
Both cars are manuals. Thanks for the info.
