Can I use the oil cooler inlet/outlet from the filter base to feed and return oil for the turbo as opposed to tapping into the pan? This will be on a 94 cobra if that helps.
Is there any option for a return that doesn't require tapping the pan? I don't want to have to pull the engine to set this up.
Dont fret it's easy and been done for years
