1 - 20 of 137 Posts
I have put my car on an aggressive diet. Here I made room for the 417 Motorsports front tubular section.
I am also going to a manual rack and manual brakes.
You can see the new flaming river manual rack. I'm also ditching almost all of the factory wiring.
HOLY COW! :surprise: That's a change..
What power plant will you be going with will you be keeping the 2v or moving up in power?
ks
The new shortblock will be using the same cobra crank I ran last year. It is going in a fresh teksid block. The new custom 11:1 Racetec pistons are gonna be hanging a new set of Molnar Turbo rods. I will be using the same 38cc TF heads and a new custom set of cams that NA SVT spec'd. Here is the slightly modified RR intake I'm gonna run. I got rid of the Logan.
I'm a bit surprised that you're not going the 4V route but I really hope to see the 2V making power again.
ks
This car will always have a 2v in it. I have a 2016 Mustang 5.0 also.
What was the delivery time on the 417 kit?
Discussion Starter #13
Powder coated some parts.
Installed quik-latches.
New door panels.
Discussion Starter #14
Engine is together.
Discussion Starter #15
Seem to be finding ways to add weight back in.
No tensioner? I tried to run my belt like that at one point when I decided to get rid of powedsteering. I ended up throwing the pump and rack back on because it was eating belts or slipping them.
Discussion Starter #17
The belt is pretty tight. The vacuum pump has adjustment.
Discussion Starter #19
Bought a really sweet relay board to wire up everything I need.
I run a boost leash boost controller. Love it!
1 - 20 of 137 Posts
