1 - 12 of 12 Posts
Im trying to pick out a cam for my 94cobra. I just bought a NOS 5115 kit and want something to work well with it but at the same time be a good street cam. Everything is pretty much stock, have pullies, 3.55 gears.(maybe a C&L 76mm dont know havent heard back from the guy) Id like to have a little lope. I know I will have to give up some driveability, but still want it streetable. Ive heard good things about the steeda #19. Thanks for any help.
The #19 is great cam. I put a E cam in a 94 Cobra (stock except for 3.55s) for a guy and man did that thing come alive, it had a very nice top end pull and was a tad stronger down low, only down side is that it doesn't want to idle very well, people aren't lying when they say the 94-95 Cobra's don't like to be cammed. I run the TFS Stage 1 in my GT and I love it, no idle issues, pulls very, very well to the top of the tach and you can def. tell there is a little something there.
I have a GT put I like the #19 cam, Never gave me a problem. I also use the 5115 kit. had it for over 5 years now. Only 2 years on this car though.
I looked into teh stage 1 cam also, but just wasnt sure if there would be any isdle /surgings issues with it so I didnt get it. It had a little more lift also and I have 1.7 rockers.
Discussion Starter · #4 ·
Guys I heard you can bump your idle rpm up a little and it will fix the surging and idle issues. Is there any way to bump the idle up with out buying a tweecer or a simular unit. Twotonefreak do think I would get better horse power from the Ecam or the stage 1.
thanks Dan
I love mine, but yes it does have some slight surging issues when trying to cruise below 1700rpms in 5th gear around town. The more I drive the car, the better the surging has gotten, I haven't even driven it for a solid month yet, and it gets better everyday. I still have some cold start problems when it is has gotten really cold, i.e 18-20 deg. at night, only one times has it actually died while warming up, usually just fluctuates between 500- 1500 for about 5 minutes and then it idles right at 800-850.
I have set the idle numerous times, 1200, 1300, 1000, and it is best with the idle at 800-900 where it is now. At 1200 it was horrible about surging and with the low idle, it is great.
I don't know which one would be best. I like the stage 1 better simply b/c it has a lot better idle qualities than the E cam, but then again mine isn't a Cobra, just a GT. They are very close. I am going to drill a hole in the throttle body plate on the Cobra I put that cam in and see if that fixes his idle problems, I am pretty sure it will. With my mods in my sig, minus the 1.6s (I also had tweaked pushrods and trashed valve spring, found that last week) when I raced the Cobra I put the E cam in from a 40mph roll I held a car lead on him until I shifted to 5th, he was just shifting to 4th (I have a 4cyl T-5) and ended up with him having a car on me when I hit the rev limiter in 5th!
You can adjust the idle with the set screw on the T-body by using a pair of needle nose pliers.
Crane 2031, Steeda #19 just to name a couple.
Discussion Starter · #10 ·
I havent heard much about the Crane 2031. I know the #19 was designed for our surge and idle problems, is the crane also designed to work with our cars to. yellow5.Slow how do you like the Crane. thanks twotonefreak
No problem. The 2031 is also a very good cam, but I have no idea how it will effect the idle and or surging.
It idles like a charm set about 800 rpms at idle. at first had a problem but the iAC and TPS were messed up on it. Cam pulls good throughout the rpm range. it sounds great also!
1 - 12 of 12 Posts
