Installing a timing adjuster this weekend and I need to know the trq specs on the pulley.
Thanks!
My 96 Service Manual says to use a Crankshaft Damper Repalcer (T74P-6316-B) and tighten to 114-121 lb-ft.
My ASP instructions say 1.) Torque to 75 lb-ft. 2.) Back out 1 turn 3.) Torque to 45 lb-ft and the tighten an additional 1/4 turn
TSB 14520
4.6L 4V Pulley Instructions
Some 1996-2001 Mustang owners, for engine performance purposes, are adding a special front drive pulley kit to reduce front accessory drive speeds. When removing and replacing the crank pulley, if the large bolt used to hold the crank pulley undertorqued, the keyway will shear and cause major engine damage. The resulting engine damage is not warrantable. If the crankshaft pulley bolt is removed it should be replaced as it is a torque to yield bolt. The installation of the crankshaft pulley requires that a specific torque operation be adhered to. The crankshaft pulley bolt must be installed using these 4 steps: 1) Torque to 75 lbs/ft 2) Back out one turn 3) torque to 45 lb?ft 4) continue to tighten and additional 90 degrees.
There's some logic for ya :blam: :idunno:
Thanks for the information.
I'll do what they say and hope for the best.
