I have found threads concerning air bag light codes based on the flash pattern. I recently purchased a 92 5.0 and the air bag stays lit, no flashing. How do I start troubleshooting this issue?
Post on the coral, because that's where I check.How do I start troubleshooting this issue?
It sounds like the Air Bag Diagnostic Controller (blue box under the dash) is dead, removed, or disconnected.I recently purchased a 92 5.0 and the air bag stays lit, no flashing. How do I start troubleshooting this issue?
Every foxbody airbag module I have seen has leaking capacitors.
I spent a long time diagnosing before I found the issue. I think I had several codes along the way 5-3, 5-2 and 3-something. I was 99% convinced it was the clock spring before I discovered the power supply issue in the module.
I have rebuilt 3 modules for the fun of it.
Hi mate,Having power applied to the module for 20 + years definitely takes it toll on the capacitors. The ones I've seen seem to suffer from the "Black Death" on the board.
Even when the caps aren't leaking, there seems to be some contamination on the boards that has become corrosive with time. Most likely due to the washing process of the PCB.
There are a lot of caps on the board, I was able to get them all from Digi-Key. The big 2200 caps can be kind of hard because the negative side is connected to a large ground plane and takes a fair bit of heat to clean up.
out of 5, I have 2 good ones. I could make another one work but it became too much work with repairing the traces.
It's fun, but I wouldn't want to make a living out of it!
I know this is an old thread, but I need some help with a diagnostic module. Enjoy the ride could you email me at [email protected]Having power applied to the module for 20 + years definitely takes it toll on the capacitors. The ones I've seen seem to suffer from the "Black Death" on the board.
What year mustang and what air bag code/codes do you have?I know this is an old thread, but I need some help with a diagnostic module. Enjoy the ride could you email me at [email protected]
Ok well that does make sense. Would you consider rebuilding one of mine ?I am only aware of the capacitors on the 92 to 93.
On a separate note, I would seriously reconsider enabling a 30 year old airbag. Just too much risk of deterioration and other issues if it deploys. I disabled mine.
Sorry, I can't.Ok well that does make sense. Would you consider rebuilding one of mine ?
