1 - 16 of 16 Posts
is that the only gear you have problems going into? if so it could be a synchro going bad on that gear.
do yu have the stock quadrant in the car?
have you tried adjusting it?is it a new cable or old cable?
how is it when yuo put it into reverse?
yu might try adjusting it a bit. Is it kind of hard to go into reverse?
yup yup stretched clutch cable, yuo need to adjust it and everything should be fine. good thing is yuo have the fire wall adjuster.
clutch adjustment will most likley take care of the problems
Banned
yup i used to have same problem...i had to go 1st to reverse, i adjusted cable and now its good...
1 - 16 of 16 Posts
