Power Adder Solutions,Inc. is a Proud Distributor for Trick Flow Specialties.
Please post your needs or PM for pricing.
We look forward to hearing from you!!
Thanks,
[email protected],Inc.
PowerAdderSolutions.com, Ford Mustang Performance Parts
Trick Flow Twisted Wedge Track Heat 185 Cylinder Heads for Small Block Ford 58cc
TFS-51405810-C01
Part Type: Cylinder Heads
Cylinder Head Style: Assembled
Cylinder Head Material: Aluminum
Cylinder Head Finish: Natural
Combustion Chamber Volume (cc): 58
CNC-Machined Combustion Chamber: Yes
Intake Runner Volume (cc): 185cc
Exhaust Runner Volume (cc): 66cc
CNC-Machined Intake Runner: Yes
CNC-Machined Exhaust Runner: Yes
Combustion Chamber Style: Heart
Intake Port Location: Standard
Exhaust Port Shape: Square
Exhaust Port Location: Standard
Intake Valves Included: Yes
Intake Valve Diameter (in): 2.020 in.
Exhaust Valves Included: Yes
Exhaust Valve Diameter (in): 1.600 in.
Valve Springs Included: Yes
Maximum Valve Lift (in): 0.600 in.
Outside Diameter of Outer Spring (in): 1.460 in.
Damper Spring Included: Yes
Number of Springs Per Valve: Dual
Retainers Included: Yes
Retainer Material: Chromoly steel
Locks Included: Yes
Lock Style: 10 degree
Valve Stem Seals Included: Yes
Valve Stem Seal Style: Viton® fluoroelastomer
Rocker Arm Studs Included: Yes
Rocker Arm Nut Thread Size: 7/16-20 in.
Rocker Arms Included: No
Rocker Arm Nuts Included: No
Guideplates Included: Yes
Guideplate Pushrod Size: 5/16 in.
Accessory Bolt Holes Drilled: Yes
Intake Valve Angle: 15
Exhaust Valve Angle: 17
Valve Guides Included: Yes
Valve Guide Material: Manganese bronze
Valve Seats Machined: Yes
Valve Seat Machine Style: 3-angle
Valve Seat Material: Ductile iron
Steam Holes Drilled: No
Oiling Style: Through pushrod
Machined for O-Ring: No
Heat Crossover: No
Quantity: Sold as a pair.
Cylinder Head, Track Heat, Aluminum, Assembled, 58cc Chamber, 185cc Intake Port, Ford, Small Block, 351W, Pair
Aluminum heads for Ford bracket racers.
Trick Flow® Twisted Wedge® Track Heat® series cylinder heads are capable of producing 600+ hp on naturally aspirated engines--they're the winningest heads in NMRA racing. Twisted Wedge® Track Heat® heads so dominated that the NMRA saddled them with a weight penalty! Twisted Wedge® Track Heat® heads include all of the features of the famous Twisted Wedge® series heads, plus higher-rated valve springs (125 lbs. of seat pressure at 1.780 in. installed height), 10 degree machined steel super locks, and manganese bronze guides to support camshafts with up to 0.600 in. of lift when used with the proper pistons. Track Heat® 185 heads take power-making to the next level. These heads feature fully CNC-profiled and bowl-blended combustion chambers and CNC-ported intake and exhaust runners to provide maximum airflow throughout camshaft valve lift. They guarantee the same amount of flow from port to port and chamber to chamber for improved power over the entire rpm range. Twisted Wedge® Track Heat® series heads work with most OEM and aftermarket intake and exhaust manifolds/headers. The heads are ready for installation straight out of the box. They come with stainless steel valves (the intakes are backcut), 1.460 in. dual valve springs, locks, retainers, ARP 7/16 in. rocker studs, and guideplates. Bare cylinder head castings are also available.
