Power Adder Solutions,Inc. is a Proud Distributor for Trick Flow Specialties. Please post your needs or PM for pricing with part numbers needed, We look forward to hearing from you!!
Thanks,
[email protected],Inc.
PowerAdderSolutions.com, Ford Mustang Performance Parts
Twisted Wedge® Top-End Engine Kits for Ford 4.6L/5.4L 2V
TFS-K519-380-375 Engine kit, 380 hp/375 ft.-lbs. torque, 44cc combustion chamber heads, each
TFS-K519-390-375 Engine kit, 380 hp/375 ft.-lbs. torque, 38cc combustion chamber heads, each
Get the most out of your Ford 4.6L 2V with Trick Flow® Twisted Wedge® top-end engine kits. Each kit is carefully tuned to deliver the right amount of horsepower and torque. Take the time and guesswork out of designing a winning combination and save some hard-earned cash. Twisted Wedge® top-end engine kits for Ford 4.6L 2V are built around a set of dyno-proven Twisted Wedge® cylinder heads with 185cc intake runners and your choice of 38cc or 44cc CNC-profiled and bowl-blended combustion chambers. You also get a hydraulic roller camshaft set, matching followers, lash adjusters, timing chains, a valve spring compressor tool, and intake and head gaskets.
Thanks,
