I am using the TF pushrods, Crane Cam 1.6 Energizer RR's. With the heads do I just use the guide plate under the stud? Do I use the washers as well?
Thanks.
Trying to remember back when I did them and dont remember seeing any washers for studs?? Pretty sure I just used guideplates and studs. Instructions were pretty detailed, if you didnt get them go to their site and print them out.
The guideplates are held down by the rocker studs with no washers. You should put some loctite on them as well.
The washers are for the headbolts. Good Luck;)
