1 - 16 of 16 Posts
I just got a deal on a Trick Flow R (75mm) intake manifold. Is there any difference on the install of that as compared to like a Cobra intake? I have installed a Cobra intake before, a couple of times, and it was easy. I've also installed a stock intake (when doing repairs on a friend's car). Is there ANY difference between the installs? Any recommendations on gaskets? I will be using ARP bolts.
I'm very curious to see what I gain on my setup from switching from an Explorer intake to the Trick Flow R setup. The Trick Flow R is designed for the 2500-7250 RPM range. Right now I am getting into boost right around 2500, so it should be good. Now, with my current setup, there is no way I can get to 7250 RPM, but when I blow the current engine up and go with a new longblock, I can reuse the intake.
Actually the TFS is easier than the Cobra intake to install :).
It comes with studs for the upper to lower union which makes the install that much easier.
Here's a Cobra Upper vs your R intake :evil:
Shawn
I didn't show it in the pic but I eliminated the vacuum hose that goes over to the plenum side. It seemed redundant to me.
Shawn
Anaconda said:
Can you explain? You just ran a hose to each end?
Well the 'T' that goes to the PCV - I left it on the Cobra intake. I just ran a hose from the barb under the intake right to the PCV valve. I was having to re-build all of the lines longer since I was building a 351.
The TFS 351w intake uses the R upper. I wonder if the R on the 302 is as tall as the intake was on my 351w.
Look at the upper relative to the fenders... or even the distributor :)
Shawn
i am too thinking of switchin to the r only because i want to run the new 3 piece intake but i have heard of fuel rail clearance issues maybe it will just be time to upgrade rails ?
Shawn
Never thought of that...why does it need 2 vacuum lines to the upper from the pcv? I have added a fuel filter inline from the pcv, maybe I'll block off the plenum and get rid of the T too.
PMS Tuning Forum Moderator
Shouldn't have any clearance issues with the rails. I don't use an intake spacer and my stock rails fit fine and now my bigger MMP rails fit just fine as well.....the reason I don't have a spacer is b/c I still have a stock hood.
Troy
Muscle Motorsport Performance....but the rails look like everyone elses..Steeda, UPR...anodized blue like all the others. I'm about to change to the Behind Bars Racing rails...much much better.
Troy
Never heard of Behind Bars....
I have heard good things about the Pro-M rails though.
What makes the Behind Bars rails better?
All the R/S and P/S guys are the the BBR rails. They are about the same as the Pro-M rails with the bend at the end to miss the distributor. The BBR rails are a tad bigger and polished finish.
Troy
1 - 16 of 16 Posts
