I bought a shift kit, AOD HP Transgo kit the instructions (well the 4 or 5 pages) are missing So I used the Video that came with it as instructions , But it doesnt cover the optional hp(hi rev) mods. I cant figure out where this (governor ) Custom Valve and spring goes , I do have a page that was with the kit , whick shows this valve being acessed but two bolts (It does not look like this is a valve on the the valve body) It gives mention on the instruction page (which is set up very bad ,like a black and white copy of a copy) - shows it being acessed by a cover plate, also mentions "It is not necessary to remove the counterweight" "the dimple installs towards the trans" in the pic it shows the valve ,red spring ,a piece that it refer's to the one end having **** and then what looks to be a small valve- inserting in to this part that I cant make out. I would call them but its sunday , and i cant find anything on the web , I need help bad , would like to get this trans back together asap THANKS AHEAD
