1 - 8 of 8 Posts
I have a tremec 3550, and when Im releasing the clutch I sometimes hear a clunk sound come from the rear... It doesnt always do it, but the only time it happens is when Im releaseing the clutch to go into neutral, or releasing from going through the gears... Stock driveshaft, stock 8.8 rear w/ 2.73's (Had an AOD). I have a new 8.8 rear with 3.73's in it, will this make a difference?
what kind of shape is your driveshaft in? mine did that with bad u-joints...
mine does that too.
I am hoping the new aluminum driveshaft I just ordered will solve that problem, as well as the vibration I have had since having my 3.73 gear installed.
:curses: :livid:
Discussion Starter · #6 ·
Original driveshaft with 155k miles. Im gonna get an aluminum, and hope this solves the problem. I also have the vibration problem.
my car does the same thing.. someone suggested to me getting an alum driveshaft too. :) on the highway at a high rpm the sucker is nuts
that is definitely your guys' problem, i had the same problem...here is why!!
1 - 8 of 8 Posts
