1 - 13 of 13 Posts
How do you get some tractions with a car with 300-400 rwhp on the street with some sorry @$$ tires? Im spinning my tires HARD in 1st, 2nd, 3rd, 4th, and 5th gear. I really cant afford some new tires right now but what are the tips/tricks you guys use to get some traction? I have UCA and LCA if its any help. Also if I do decided to get some tires in the near future, what should I get?
Get some dot approved drag radials that are legal for the street man. Fit the biggest you can on your rims. What car do you own and what mods?
1994 convertible mustang gt w/ 347 cp 9.8, AFR 185, Compcam XE274HR, 2 stage ported Edelbrock RPM, 1 5/8 LT headers, 4.10s gear, and 3550 Tremec. The rims are 17 x 9 and 17 x 10.5
Drag radials should help, but wont solve your problem unless you tub it out or something. it must feel great to have all that power.lol what hve you run in the 1/4 mile?
Discussion Starter · #5 ·
I dont know yet, I went from completly stock to completly stroked. Im still working out some bugs that the car has then it will see some dyno time and after it will see some 1/8 and 1/4.
P.S. My tire spin is just from 1/2 WOT and 3/4 WOT.
thats extreme. wow
umm what kinds of tires are you running right now?
As previously stated; you will need to invest in some big & sticky tires. Out of curiosity, have you done anything to the rear chassis yet? How about the front shocks\springs?
If it were me, I'd get a good set of adjustable uppers and set the pinion angle at about -3 and see what that does... But you are still going to need a decent tire.... Have you seen Mickey Thompson's new Drag Radial? From what I've heard and seen, I bet they will be a sticky tire.
Quicker weight transfer would help also. Some Lakewood 70\30 struts & Moroso drag springs up front will be ok for the street & really help "plant" those tires you're going to purchase.......50\50 Lakewood shocks out back too....
and dont; forget to drop the air pressure in the rear tires either.
young316 you jinxed me didn't you? I knwo it was you!!! I went to the track tonight and got crappy traction all night. I was so frustrated I left after 5 passes. ohh yeah the burnout I did while still in reverse didn't help out matter much HAHAHA
1 - 13 of 13 Posts
