I didn't make it to corral day but i did make it to the track. I went to New York International Raceway Park. I did finish 2nd in the Trophy Class. I was dissappointed in my times, It was only my 2nd time to a track, and my first time with this combo. The timeslip said it was 77 degrees (our thermometer said closer to 87 degrees) with 95% Relative Humidity.
The best Time Slip says :
RT .891
60' 2.285
330 6.200
1/8 9.320
mph 78.94
1000 12.012
1/4 14.260
MPH 100.81
How does the times look? What should this combo run?
I had my street tires on (Dunlop SP Sport FM901). I also still have 2.73 gears, stock injectors and mass air meter.
Those times are pretty similar to mine.......Except mines and 85 and has stock heads and cam. Your car really should be faster than that, probably around the 106-108 mph range. With heads/intake/cam, gears make a HUGE difference because they get you in the power band way sooner. Get some gears then go back to the track and try again!
