Can some one tell me exactly how to calibrarate the tps. I need to know what color wires to check and what settings to have the meter on so I can check the volts. I would do a search but I'm runnig out of day light.
the top wire is 5volt constent
the middle wire is the signal wire back to pcm ranges from .8 idle to 4.6 WOT
the bottom wire is ground.
at closed throttle it should read .8 and very smoothly open the throttle and the volt should increase smooth up to 4.6 volts at WOT.
