1 - 11 of 11 Posts
That is my question. I have a 96 Cobra that I drive mainly on weekends and race everytime the track is open. I have an opportunity to get some 33 spline axles at a decent price and was thinking how I could justify (to myself) buying them, and a spool would be a hell of a lot cheaper than a 33 spline Eaton. Basically my question is how do they handle on the street?
Anyone runnign a spool on the street?
Alex
To me it's liveable. Turns are slower and wider and I do run tall soft tires to absorb some of the twisting force. You'll know it's there though, no denying it.
I know I wouldn't be happy with it in a daily driver but weekend toy and track beast I'm happy with my choice.
Be sure to factor in the cost of C-clip eliminators as well. You need them as the stock c clips don't work with full spools. I'm not sure how they work on factory rear disk brake equipped cars though.
Spool?
I just put one in two months ago! Have driven about 250 street miles and few passes at the track... Marginally streetable but if your careful not to bad.... better with ET Streets than Comp TA's.
Actually I like it.....but not for the corner carver!....Mark
Which one would be cheaper....a spool set up or a diff/axle set up? I'll be doing one of these maybe in the summer and I just wanted to know.....
Spent $ 190.00 for Moser spool, and $ 140.00 for C-clip eliminator kit, so $ 330.00 total parts vs. $ 539.00 for Detroit Locker, looking at $ 200.00 total.
If money is not the object, locker might be the way to go.
I put on about 3-4k street miles each year, do you think a spool would be a good choice for me or no?
Been driving on a spool in my car for over a year now. After 20K miles I can say I don't regret the decision to go that route one bit. I like having the piece of mind knowing that my car will not break versus a little inconvience around tight corners. In fact if anything it's also helped me keep my driving within reason because you can't take corners too fast.
Bill
Correct me if I am wrong but dont Detroit Lockers lock up the rear end too, making turns about the same as a spool? 539 is a bit much.
I am currently looking for a trak loc 31 spline unit from an f140. Going to a 33 spline carrier might be a little more than I am willing to spend right now. Even with the deal I was gonna get on the axles, Eaton and F150 31 spline rear ends are rebuildable and sold used around the internet and boneyards much more often than the 33 spline diffs. I might get away with a decent setup at a reduced price. Thanks for all your help guys
Alex
Is the spool quiet? I was never really into taking hard corners anyway so I am now leaning towards a spool.
Detroit Lockers lock up when you are going striaght and unlock when you turn.(thats the clunking noise you hear)
spools are quiet...the only thing you will hear is the tire chirpping.
fwiw...i went with a spool
Whats the difference between a mini spool and a full spool? I have a stock 8.8 housing currently using 31 spline moser's, auburn pro and c clip eliminators... thinking of going to a spool next time the rear is apart. I had a home made spool, by welding up the stock spyder gears, and it was great. The car never went so straight...
1 - 11 of 11 Posts
