I am installing a TKX into my 1989 GT. Looking at drive speedo gear in TKX, it is a 12-tooth gear. What or where do I find the driven gear, gear on speedo cable, to get things matched up? I will be running 3.55 rear gears if that helps.
I purchased the same transmission from the same vendor and I do not remember any option for speedo gears... Can't tell you what mine has as I havent got that far on my project yet...Bought from Summit, TCET17765. I downloaded the Manual from Tremec, and it shows a 12-tooth gear on output shaft for Ford, 17 tooth for GM
