The 275's will work great all the way around.
If you can swing it, I'd recommend a 285 or even a 295 on the rear only.
Good luck!
Ryan
so there is no issues with rubbing at all?... i was thinking abotu putting a 1" spacer on the rears aswell... should everythign still be okay?
Don't forget that certain tire manufacturer's tires are slightly wider than others. For example when I ran Continental tires and then switched to Nitto's the Nitto's were slightly wider.
If anything you should be fine. Maybe a slight amount of rub if you turn the steering wheel full left or right, but again that depends on the tire manufacturer.
If you are running the saleen wheels you should go with what they recommend. They run a 265-35-18 on the front and a 295-35-18 on the rear.
Good luck!
Ryan
