Do you have to change the oil pan gasket when replacing the timing cover gasket? I bought a fel-pro gasket set for my timing cover and noticed it came with the corners for the oil pan.
The front row of oil pan bolts bolt into the timing cover. So when you remove the timing cover, you'll disturb the front section of the oil pan gasket.
Pete
Thanks I hadn't even thought of that
