i got my timing chain cover and water pump and gaskets..everything looks good...earlyer i purchased a ARP bolt kit for a 351...in that kit they gave me four bolts for the timing chain cover..one was longer...so far only two fit..at the top?? they also gave me some bolts for the water pump and they dont seems to be right...the timing chain cover has a few bolt holes at the bottom that are bigger then the rest...do i need different bolts? the whole timing chain water pump thing is really confusing me...any thoughts or anyone have a web page that goes into detail on this?
86 4 eye, 410 stroker, holley sniper, T70 single turbo, lentech aod, xbrake, 3.55's, k member, 5 lug
i did a 4 to 8 swap, so i didn't have a clue either. i just looked at my buddy's and that was that. the real long one goes thru the w/p, the p/s, the a'c spacer and the t/c cover. 3 big studs go thru where the acc. plate mounts for a/c. i just went to the junkyard and got my bolts, $5, lol.
anyone else?? anyone know if i cant get the bolts i need from just a parts store??
