I was at the post office today and it went from a grinding sound to an all out squealing and I started seeing smoke from under the car. Is $250 about right for parts and labor?
Thanks for the help.
Yup
$250 seems a pretty good number, if you can find somebody to do it for that.
Are you sure it's the TOB? It shouldn't SMOKE unless it's WAY gone.
Good Luck!
Labor to do a TOB will be the same for a clutch replacement. While you're in there, do it all: Clutch, pilot bearing, throwout bearing, clutch cable, pivot ball maintenance and clutch fork maintenance/replacement (pivot ball and clutch fork just need to be checked for acceptable wear and tear).
You'll spend about $300 in labor for all that. Parts vary, but a clutch is around $160 and up, TOB is around $20-30, same as pilot bearing, clutch cable and quadrant are about $90-120, and the fork and pivot ball, you'll have to check on.
Good luck.
Doug
