1 - 16 of 16 Posts
I ran my codes the other day and got “Throttle position sensor out of range”. I have been trying to test it today and my multimeter is giving me just 0 for my reading. This is a brand new multimeter. I connected the positive to the green wire (dont have any sewing needles to pierce so I dug out an area with a screwdriver) and I placed the ground the black wire. I turned my key to the run position as well. I must be doing something wrong. Any ideas?
Banned
what you are measuring is the elec potential between the sensor ground and sensor signal
if both are the same, your meter will read 0volts potential
take your ground probe to batt negative and read
I’m not sure what bat negative means (I dont know much about wiring) but I followed a really detailed explanation of measure the TPS and fact checked it with a couple of explanations of people doing the same thing, so I feel like I am reading the right wires....
yes that is correct. I thought the pink wire at the tps was voltage and the green wire was the signal back to the ecu. Put the black lead to ground and probe all 3 wires and see if any of them have 5v when the key is on.
The negative terminal on your battery is battery negative aka ground.
Discussion Starter · #7 ·
Alright thanks, will do tomorrow.
On a car this old, the electrical connectors should be considered the likely cause. The salt-n-pepper connectors (the white one has all the sensor inputs to the EEC) and the individual sensor connectors can get oxidized. Every so often that happens with my TPS - the symptom is a hanging idle. When that happens, I break out the contact cleaner and hit the white connector and all the sensor connectors in the engine wiring harness.
Banned
BATTERY negative post
the black wire, MIGHT NOT be connected to the battery, open circuit
Also checking at TPS is only testing there, you also have to test at the ecm, if the testing at the tps is okay
Discussion Starter · #10 ·
So your saying there is a chance the electrical connection is broken so my TPS is completely out of order? Sorry but what does a hanging idle mean? I looked online but I cant find anything. My car will idle fine when I first start it or when I first come to a stop and then after 15 to 20 seconds or so it will start dropping rpms every couple seconds, kind of like a stutter.
Discussion Starter · #11 ·
Alright so connect my ground to the battery, and connect the positive to the TPS sensors green wire, correct?
Banned
one lead on green
one lead on black, then move the lead on black to bat negative
Old connectors get oxidized and don't connect. This is why contact cleaner was invented.
By "hanging idle" I mean when I start driving the car, it idles at a normal speed, but after a while when I come to a stop, it doesn't drop to normal idle speed. This is what happens when the TPS signal goes to 0 and then reconnects.
Your symptoms sound different, but if the EEC sees the TPS at 0 volts, it could be either the TPS connection itself or the white connector to the chassis harness.
I’ve had this issue in the past too. Cleaning the 10 pin connectors is the solution.
Interesting when it happens when you’re datalogging.....It shows a part throttle condition even when you’re not touching the pedal.
Datalogging is how I discovered what was going on.
1 - 16 of 16 Posts
