Got everything nice and tightened down, however, when putting the rack & pinion back on, ..... I'm assuming that the spacers that the long bolts go through need to be transferred over to the new tubular k?
I tried putting the spacers on but the stock bolts appear to be too long or I'm missing something here.
Anyone else that put this tubular k member in, did you have this same problem and am I missing something obvious here or ?
Did you have to use shorter bolts or did you use the stock bolts?
Any pictures would be even more helpful.
Thank you,
Tim
There should have been 2 bolts that came threaded into the rack mounts on the K-member. They should have been 2 very nice and shiny bolts.
You will need to remove the BIG washers from the old bolts and then you will need to drill them out about 2 bit sizes bigger. You will re-use these washers on the new bolts that came with the K-member.
I will check back on this thread just in case you have any other questions.
Discussion Starter · #4 ·
I don't have these two bolts :( Do you happen to know what the specs of them are? Length and size? I'll go get them from the hardware store or something.
Tks,
Tim
