I don't know the exacts, but I went about 105 ft-lbs on the crank pulley. The water pump and alternator I pretty much guesstimated. Zapped the alternator on with an impact wrench, and got the 4 on the water pump pulley just good and snug.
I agree zap the alt. with impact gun the haynes manual says 96 torque the crank bolt to 114-121 ft lbs, the 97 and later is a 4 step prosses ? i torqued mine a 1997 to 110 never had any problems
step 1 66 lbs
step 2 loosen one full turn
step 3 36 lbs
step 4 tighten additional 90-degrees
sounds crazzy they must have there reasons
water pump pulley is 15-21ftlbs
