Any tips for doing this on a '95? I've got the trans out of the wife's car getting rebuilt. Already has offroad H pipe. I had the tube still connected w/ a short piece of high heat rubber hose. I'd kind of like to dump it and the plumbing at the back of the heads.
What do I need to leave to not trigger any check engine light crap? Pull plumbing but leave solenoids and vaccum connections?
Only issue should be cold start, right?
You will need a chip to turn the thermactor system off at the computer, otherwise I don't know a way to prevent the check engine light.
I use an EEC Tuner.
bullit_stang.....thanks for the link! did you completely remove the solenoids as it looks in the pics?
already have a chip for the gear install and I'm not payin' to reburn for this! LOL I'll leave the solenoids in if I have too (ala EGR bypass).
