1 - 20 of 272 Posts
So my car has been sitting for over 7 years in my lane way just looking a me as I walk by it to get into the house I've finally decided it needs to be brought back to life as I'm not getting any younger and life is to short (I've had a few very close people pass away within the last two years).
So a little back round information on how it came to sit this long, after losing my job (and going threw a divorcee) because of restructuring at work and then being lucky enough to get another job (within the same company that let me go) I decided I'd upgrade my heads as I felt that my ported RPM performers were holding back my 358W T trim feed engine, have a buddy that wanted to buy those I sold them. Then of course as life goes another curve ball, work was being cut to 4 days a week, hum, what to do, buy heads or pay my mortgage, lets just say I still own my house. Now the car was sitting with no heads on it and I knew that number 7 cylinder was hurting form a blow head gasket at the track one night (checked the compression before removing the head and it was only 70 psi with oil) so I decided I may as well tare it down to look into that. When I removed #7 piston I found that both rings were broke, as I removed the rest of the pistons I found 4 more that had broken rings (note to self, don't try and tune an engine without a wide band o2), maybe it wasn't those heads that were slowing me down. Anyway that's how it sat for 7 years, paying support and other priorities in life left little to no money for my car. Roll ahead to 2015, I have a new wife, a better paying job and a little more time.
I decided over the years that I wanted to build a blown 408 so I purchase a stroker crank and rods, I then took my block to the machine shop to have it checkout out and was told it would need another .010" to clean it up so while they were doing that I ordered the .040" over pistons with a 23 cc dish to keep my compression down. It was winter when the assembly showed up and my plan was to but the short block together in the garage until I found out its way to hard to do anything in a non insulated garage, -30 degree freezer. I spent the rest of that winter insulating it. I then spent the summer painting my house which I started the summer before. Which brings use to fall of 2016.
My car sitting in the lane way wasn't overly kind to it so it needed to go for paint. I wanted to try and do this myself but without the proper area and equipment to to it I decided to sub it out. Below is the car sitting at the painters before unloading it
Discussion Starter · #2 ·
I stripped down the car on weekends over at the painters.
  • Like
Reactions: 393200
No sure why the pictures are coming in sideways, they are not that way in the folder.
I had the dreaded passenger side shock tower / frame rail rust problem which we fixed all up and it looks awesome. He took pictures of this with his camera of the repairs but his camera when for a #### and we lost all those pictures.
Car getting a little primer on it and the repaired frame rail.
Discussion Starter · #4 ·
What you may find if you let you car sit for 7 years and the door seals dry out and fall apart on one side. It's not as bad as it looks as I was digging at the rust and spread it around.
Discussion Starter · #5 ·
I went to the paint store and looked over 100's of shades of blue, I was after something like true blue metallic. For a place that sells paint there lighting in the store sucks, it was hard for me to pick out the blue I wanted with pictures that I had on my laptop which I took with me. The one I picked was tri coat paint and you could pick fine or course metallic, I picked the course. We then did a test on the back of my hatch with using the grey primer as the base, we needed to use 5 coats to cover the grey and if it wasn't even it was all spotty. Also it didn't come out dark enough for my liking so we did a hatch hinge as a test using black primer, the result was a deeper blue with only a couple coats and a lot more even.
Discussion Starter · #6 ·
Because the paint was 20 years old and cracking we stripped the car down to bare metal, but those pictures are lost with the camera problems. I the pictures that I'm posting were taking with my phone so not perfect but better then nothing. Here are some pictures with the car all done with black primer.
Discussion Starter · #7 ·
During the painting going on I decided I should clean up my quarter window moldings so I brought them home and sanded them up. The last time I had it painted we ended up lightly sanding them, painting them with a flat black and then clearing them which made the ruff pitted surface much better but still left them a little ruff. So all I did was sand down the clear to smooth them up and then painted them with velvet black to look more like they did when new. Can't seem to find the pictures of the finally product but you will see them on the painted car photo's.
Discussion Starter · #8 ·
Started to get some paint on the car, when I walked into the shop I think I started to get a woody. lol
Discussion Starter · #9 ·
I went over a couple night threw the week and sanded my body kit and put them on the next night.
Discussion Starter · #10 ·
I pushed it outside to get a picture, not too bad, I haven't got a picture in the daylight yet thou
Discussion Starter · #11 ·
Went over a few weeks ago and put in the new front lights, if you look close you will see that the headlight isn't sitting 100%, the new headlights didn't come with the new mounting brackets, the ones from the old lights were cracked and have the adjusting bolts stripped or seized, I going to have to order new ones.
  • Like
Reactions: mb92gt99gt99light
Damn, 7 years is a long time brother! Very happy to see you making progress on the car again and more importantly all the positive life changes. Great intro! I'm loving the colour scheme and the hard work you're putting into it. All the hard work you're putting into it now, makes it all the more satisfying when it's all said and done (like that ever happens lol). Good luck with the resto build, I'll be following along with interest.
Do you have the short block built and back together? Have you figured out which heads you're gonna put on?
P.S.
I'll be sending you a chiropractor bill! lol
Stan
Discussion Starter · #13 ·
Thanks Stan.
I planning on doing the engine build soon (still doing the honey do list which includes repaint the whole inside of my house). I'll post pictures as I go (and yes I did find a set of heads). Also people with a sharp eye may have noticed the lack of a hood in my photos, I'm unsure if the new engine combo will fit under my current hood so we never painted it. Need to get it done so I can finish up the paint job.
Looks awesome. I can't wait to get a garage, and start another build myself.
Discussion Starter · #15 ·
So I picked up another piece of the puzzle, after 180 buck, a 6 hour drive and 50 bucks of gas it's all mine. It has an extra 1" over my last hood so it should work.:smile2:
  • Like
Reactions: coupe1993
Discussion Starter · #17 ·
So it's been a busy weekend. Testing fitting the hood and trimming it to fit, what a pain. I needed to trim the back edge on the passenger side and adjust the hings all the way over, you would think 30 year old hings wouldn't be hard to adjust..... lol
Discussion Starter · #18 ·
We started at 10 A.M. and I didn't leave until 1 A.M., long day
Discussion Starter · #19 ·
missed a picture, maybe didn't take one of the masked off black, but here is the center masked off
Discussion Starter · #20 ·
And the finish hood
1 - 20 of 272 Posts
