1 - 8 of 8 Posts
Getting ready ot install it and I want to make sure I have the vacuum connections correct. Heres what I'm planning, please tell me if its right:
#1 connect to line that runs behind dist to cannister
#2 block off (plug)
#3 leave as shown and connect to PVC
#4 block off (plug)
http://www.netSnapShot.com/b?ACCOUNT=2714&KEY=4
goto last pic in this album and you'll see a pic of bottom of intake
Discussion Starter · #4 ·
Isnt that taken care of by the manifold (has three connections) that is bolted on but I did not point out, next to #3?
What I did was ran a hose from to the the T fitting in 4 and then connected the other end to the PCV. I then used the stock vacuum fitting with the 3 lines and connected that to the brakes, Fuel Reg and I can't think of where the other went. The one on the front I use for the gas tank canister.
Forgot to add the hose into 4 comes from 2
I think I might have the vacuum fitting in 3 and the other one blocked off. I'll have to look tonight just to make sure.
1 - 8 of 8 Posts
