I just swapped out my cobra intake for a TFS track heat. I started it and it would barely run. My vaccum guage wasnt moving at all. Stuck at 0. I connected my PVC to the hole in the upper plenum on the drivers side. I plugged three of the four holes on the under side middle of the upped plenum. The fourth hole I connected to the canister thing. I am using an intake elbow adapter for my 95. The hole in it i have connected to everthing else like vaccum tree, egr, blower bypass, map sensor, fuel pressure regulator, and FMU. I have a plug in the lower number 5 runner also. Is there any other vaccum connections I didnt see? My intake didnt come with directions and ive looked on the trick flow website but I dont see what i missed. Any help or ideas on what to check?
Discussion Starter · #2 ·
ok, im just guessin here, but this could easily be your prob.
if you have an aftermarket fpr, the egr can could be holding the upper off the lower a little on that corner, and could be responsible for the very low vacuum. it has to be something huge, as even with a few major leaks i have had over the years the worst caused me to have about 4" at idle. try and stick a small flat head screw driver between the plenum and the base at the right rear of the intake.
good luck
Discussion Starter · #4 ·
Thanks for the input matt. i check the clearence and i have prolly 3/8" between the areomotive AFPR and my upper/lower intake. it seems to be set down evenly between the upper and lower. i torqued the upper to lower at 20 ft/lbs. anyone else have any ideas? i havent set the timing yet because it wont hardly run. i did manage to check it and it was about 3/4"-1" to the drivers side the the timing mark. the timing being this off couldnt cause my car to have no vaccum could it? can i set the timing using just the starter while turning it over?
Discussion Starter · #5 ·
i also checked the clearence between the egr and the passenger side valve cover and i have approx. 1/4". i rechecked all vaccum connections again and i swear everything looks right.
Discussion Starter · #6 ·
I feel stupid. It was just timing :eek:
