1 - 8 of 8 Posts
I suspect mine of failure. Need to replace. Don't know much about them. Can they be replaced with an aftermarket ignition system? Anybody had these go out? Can't find a used one.
Thanks Corral
Buy a new ford one for about 50 bux. It's a different part than the aftermarket ignitions like msd, crane etc. It will go out eventually, its just a matter of time.
Well if you have an Autozone in your area they can test it. I suspected mine as well (turned out to be both the TFI and the PIP sensor in the distributer) and they confirmed that it was out. This happened maybe 9 months ago, no problems since.
Discussion Starter · #5 ·
autozone
Thanks guys for the info. I'll try autozone. Ford wants $121!!!!
John
Ford does not make their own TFI module, they are made by Borg and warner if I am not mistaken, buy from PepBoys or local auto parts they are cheaper.
I thought Ford but the TFI modules on the fender wall on the sn95s so they won't burn up from heat on the distributors like the earlier designs did. I had mine tested at autozone twice and both times it came back OK. I was temped to buy the Wells unit but they insisted not to. The other thing I noticed is that the Ford unit is built better than the autzone unit to the eye, but I have installed a Standard brand TFI on an F250 and it looked closer to the stock unit construction.
Oh well, I guess I will play the get my stang stranded on the highway for now and see how long a stock unit will lasts.
1 - 8 of 8 Posts
