1 - 1 of 1 Posts
Two questions for you Vortech guys.
One, how did you guys get to teh stock tensioner to release the tension in order to get the belt on?
Two, was the belt that Vortech supplied long enough to go all the way around without rubbing on anything?
I used a large pipe pliers to grap the bottom of the tensioner and turned it that way but it was a BI+CH! :confused:
Is there a better way to get to it?
Also my belt looks like it's rubbing on the block a little just above the tensioner. The belt is so tight that the tensioner is like almost straight up. With the belt in place the tensioner has less than an 1/8" of travel until it is completely released. Is this right?? I was thinking of getting a little bit longer belt, but didn't want to make it too loose. Any ideas?
1 - 1 of 1 Posts
