Sometimes, all the sudden my Tach will go out and then later on it'll come back on. Is this normal for our cars? Do I need to replace my whole cluster? It's getting annoying...
-Code
Tom, when you hooked up that window switch to that PCM are you sure you didn't sever the wire, causing a bad connection to the gauge cluster?
Just a thought.........
Like I said before, to bad you aren't closer, cuz I'd glady help you out.......
Discussion Starter · #4 ·
As far as I know, I didn't sever a wire. It could be because I quickly shoved my PCM in there. I guess I'll go look at it tomorrow again. Sigh. I hate working anywhere near that PCM.
-Code
