1 - 11 of 11 Posts
I picked up a used T5 for my '93 4 cylinder. I don't know anything about it other than the seller said it works fine (car wrecked), and I have it apart looking-and see nothing wrong. It's a 3.35 94-95 v6 box, going behind maybe 300 engine HP turbo 2.3, street car but I drive it not hard, but spirited and the stock T5's shift quality is a little on the notchy side. I know the input shaft is different...that is being addressed as we speak.
For you guys who do your own T5's, is there anything that I can do while rebuilding it with new synchro's that can improve it's shift quality? No I have not bought any parts yet but have bearings, seals, etc leftover from prior rebuild.
The T5 should shift like butter. This transmission is known for its excellent driveability and gear engagement.
If you are primarily looking at good shift quality, I would look real close at the sliders and syncro teeth on #2 and 3 mainshaft gears. A good proper shim up job on the counter gear and mainshaft goes a long way also.And of course a good quality lube.
The input shaft will be too long. You will need a spacer or to swap out the input shaft for a Fox length unless you are also running the 94-95 bell housing.
EDIT: whoops I missed the input part of your post on my first read.
I switched to bronze shift fork pads and I noticed a huge improvement in how "tight" the trans felt when shifting.
While its apart I would go ahead and upgrade to Billet shift keys, and a bronze shifter bushing.
I have them but what is the advantage of billet keys? They look identical to the OE ones I pulled out, other than being stronger billet material.
astro is cutting an input shaft.
Bronze shifter cup bushing—where’s an advantage there? Is NVH going to be a big deal with it? Remember—this is a 4 cyl application
have all the synchros done. 2nd and third gear look absolutely brand new as does everything else inside including the sliders. 5th slider was a little worn but I could t see the wear without a magnifying glass, replaced the gear and slider anyway since I had them from a previous project. I’m very impressed with it all given it had 70 some thousand miles on it.
bronze fork pads done.
1 - 11 of 11 Posts
