Good used T5 10 spline input shaft with bearing on it. Bearing spins good, came out of a working trans. $55 shipped
Everything below is NEW still in the boxes....
2 Oem Ford diff spider shafts
One box has just the cross shaft
The other box has shaft, retaining bolt, and 2 c-clips
Both are in original Ford box..The pn #'s are E9AZ-4211-A
These fit mannyy diff ford rear and even some GM rears and other applications
First box $15 shipped
Second box $25 shipped
I also have some axle bearings and axle seals which should be for the same rear but I will check first but I will sell everything as a complete kit if someone would like.
What year trans is input shaft out of? And can you take some pictures of the wear on the gear and any other wear areas?
Hey, not sure what exact year I just know it was from a T5 I had in my foxbody. Here's some pics..Lmk if you want anymore!
