I'm replacing the belt weather strip that runs along the front and back of both T-tops on an 85 Capri. There is a piece of molding that runs between the T-tops in the center of the roof that I'm having trouble getting off. I found 2 screws securing it, one under the map light and one under the dome light. Is there more behind the headliner? It also seems that Ford used some of that super bond glue stuff to secure it. Has anyone ever removed one of these? Any suggestions
For reference the T-top division bar is held on with the two screws and some very sticky two sided foam tape that runs the length of it on the bottom side.
As noted above, you should be able to replace the felt strips without removing it, though.
