hurst roll control part#174-5000 like new for 80.00
B&M ratchet shifter for forward pattern c-4 transmission with cable for 250.00
B&M prostick shifter for a powerglide transmission like new for 300.00
B&M prostick shifter for a c4 transmission forward pattern like new for 300.00
Aod stock converter like new for 100.00
10" 3500 convertor with anti balloon plate for c4 used for 600.00
10" 3500 convertor for a turbo 350 transmission used for 250.00 firm
(3) Ford racing aluminum driveshafts for mustang used 275.00 firm each
(1) Ford racing aluminum driveshaft with a 31 spline yoke for mustang used 275.00 firm
(2) sets Hpm solid motor mounts used for 80.00 each set
Mustang Driveshaft Spacer with bolts 11/16" Thick new for 40.00
Upr driveshaft loop new for 40.00
(2) Upr driveshaft loops used for 30.00 each
(2) sets of energy suspension motor mounts like new for 125.00 a set
fan shroud with overflow for foxbody used for 75.00
Fluidyne aluminum radiator for 94-98 mustang like new for 300.00
Mishimoto alumium radiator for mustang used for 200.00
Howe racing alumium radiator for mustang with quick connects and cap brand new for 250.00
(1) aluminum 3 core radiator used for 180.00
Afco aluminum radiator with electric fan both used for 200.00
(1) 3 core radiators for foxbody used for 100.00 each
(2) Taylor aluminum battery boxes new for 90.00 each
Caster camber plates for sn95 used for 125.00
Rci harness part #9210d new in the box for 60.00
Kyb shocks and struts for a foxbody like new for 150.00
(2) sets of Hpm megabite sr adj lower control arms in good condition for 250.00 a set
(2) sets of Upr adj lowers like new for 175.00 a set
(1) set of Southside lower control arms used for 125.00 a set
Hpm adj uppers like new for 150.00
Black tubular uppers with solid bushings for 125.00
bbk blue upper control arms like new for 75.00
silver solid upper control arms in good condition for 100.00
Upr bump steer kit for foxbody with power rack new for 140.00
summit brand part#g4961 transmission cooler new in plastic for 30.00
Qa1 10-150 coil over springs like new for 75.00
eibach 278246 rear springs like new for 80.00
eibach rear drag launch springs without bag for 100.00
eibach front drag launch springs for 75.00
bbk 2501 1 1/2" front springs brand new for 100.00
(3) Ford motorsport clutch and pressure plate setups for 5.0 mustang used for 100.00 each
(1) king cobra clutch and pressure plate setup for 5.0 mustang used with low miles for 150.00
Ram 10 1/2" 10 spline 900 clutch kit with 200 miles on it for 250.00
Steeda tri ax shifter for tko like new for 140.00
Mgw shifter for tko 500/600 used for 140.00
upr shifter almost new for 125.00
(1)B & M ripper shifters for mustangs in good condition for 125.00 each
hurst short throw shifter used for 100.00
(3) pro 5.0 shifters with handle for 130.00 each
automatic pedals for foxbody used for 100.00
T-5 bell-housings for foxbody used for 250.00 each
Complete T-5 5 spd world class transmission setup includes a 4cyl transmission with v-8 bellhousing,plate,clutch fork,B&m shifter and clutch, pressure plate and release bearing all for 900.00
(1) T-5 5 spd world class transmission with low miles on rebuild for 1,200.00 firm
T-5 transmission for a 94/95 mustang gt for 1,200.00
Aod transmission in great condition with very low miles on rebuild and shift kit for 1,000.00
C-4 transmission with a forward pattern valvebody,Red clutches, small bellhousing, Kevlar bands for 1,100.00
C-4 transmission with forward pattern valvebody,Red clutches, small bellhousing, Kevlar bands, billet servo and deep aluminum pan low miles on build for 1,100.00
(1) 28 oz. 157 tooth flywheel for ford used for 175.00 each
(6) 50 oz. 157 tooth flywheels stock 87-95 for 50.00 each(need surfacing)
(1) 28 oz.flexplate 157 tooth for ford used for 75.00 each
(1) 28 oz.flexplate 164 tooth for ford used for 75.00 each
(1) 28 oz.flexplate 164 tooth accepts ford of gm converter like new for 125.00
(4) 50 oz.flexplates 157 tooth for ford used for 75.00
(2) 50 oz.flexplate 157 tooth for accepts ford of gm converter like new for 125.00
50 oz.flexplate 164 tooth for ford used for 75.00
Steeda Double Hook Quadrant for 50.00
double hook quad for 50.00
(4) adjustable clutch cables almost new for 30.00 each
(3)sets of 4:10 gears for 8.8 used 140.00 each
(1)set of 3:90 gears for 8.8 used 185.00 each
(1)set of 3:73 gears for 8.8 used 140.00 each
(4) sets of brand new ford racing 3:73 gears for 8.8 185.00 each
1 set of 3:73 gears for 9 3/4 used for 125.00
(2) sets of used 3:55 gears for 8.8 135.00 each
1 set of richmond 3:55 gears new for 185.00
1 set of brand new ford racing 3:55 gears for 8.8 185.00 each
1 set of used 3:27 gears for 8.8 135.00
Ford racing ring and pinion install kit part #4210-B2 new for 95.00
(1) 31 spline t-lock carrier for 8.8 rearend used for 200.00 each
(1) 31 spline t-lock carrier for 8.8 rearend with carbon fiber clutches used for 250.00
moser mini spool for a 8.8 new for 100.00
(2) complete drum to drum stock 8.8 rearends for foxbody mustang for 850.00 each
(1) complete drum to drum 8.8 rearends for foxbody mustang with 3:73 gears for 950.00 each
1 complete 4 lug built 8.8 rearend for foxbody consist of 35 spline strange axles with long studs,spool,3:27 gears,c clip eliminators and a girdle cover all for 1,500.00 firm
1 complete 4 lug built 8.8 rearend consist of 31 spline moiser axles,spool,4:10 gears,and c clip eliminators all for 1,500.00 firm
1 complete 4 lug built 8.8 rearend for foxbody consist of 31 spline axles with long studs(needs 1 replaced),31 spline locker spider gears welded,4:10 gears,and poly bushings all for 950.00
1 complete 5 lug 8.8 rearend for foxbody consist of 5 lug axles,auburn unit,3:27 gears,and disk brakes all for 1,000.00 firm
1 8.8 disc brake rearend for 99 thru 04 mustang with 3:27 gears,gt calipers and rotors (needs pinion bearing replaced) all for 650.00
1 8.8 disc brake rearend for 99 thru 04 mustang with 3:73 gears and gt brakes and calipers all for 850.00
I may consider shipping small items only but shipping and PayPal fees will apply, Pickup in Barnwell s.c.29812 is preferred 803-300-0855 (please call or text for faster response and only ask for pics if serious about buying i stay very busy with my full time job)thanks
